Einleitung
This guide will allow you to separate the motherboard from the lower case.
Was du brauchst
Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Fast fertig!
Abschluss
