Einleitung
Want to have a newer/faster network card? Follow this guide, it will show you how to replace it.
Was du brauchst
Loosen all four screws and remove the back panel.
Remove the back panel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
In the red circle is the network card
Remove the two wires (inside the green circle)
Place the spudger as shown in the photo. The network card will pop up. After that you can remove it and replace it with another one
To reassemble your device, follow these instructions in reverse order. Be sure to connect the wires the same as in step 3.
2 weitere Personen haben diese Anleitung absolviert.
