Zum Hauptinhalt wechseln
New Speed 26-inch Electric Bike Throttle Replacement
Was du brauchst
  1. New Speed 26-inch Electric Bike Throttle Replacement, Electric Bike Throttle: Schritt 1, Bild 1 von 1
    • Remove the 3/32" Allen screw from the top of the throttle.
    • When removing the screw, make sure the wrench is well seated to avoid damaging the screw.
    • Make sure that your bike's power is turned off before beginning to disassemble it.
  2. New Speed 26-inch Electric Bike Throttle Replacement: Schritt 2, Bild 1 von 1
    • Remove the 5/64" Allen screw from the underside of the throttle.
  3. New Speed 26-inch Electric Bike Throttle Replacement: Schritt 3, Bild 1 von 1
    • Slide the throttle off of the handlebar.
    • Be careful when removing the throttle. Taking it off too quickly could result in damage to the wiring.
  4. New Speed 26-inch Electric Bike Throttle Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 2mm Phillips screws from the back of the control box.
    • Repeat this process for the other side of the control box. 4 screws will be removed in total.
  5. New Speed 26-inch Electric Bike Throttle Replacement: Schritt 5, Bild 1 von 1
    • Open the control box.
  6. New Speed 26-inch Electric Bike Throttle Replacement: Schritt 6, Bild 1 von 2 New Speed 26-inch Electric Bike Throttle Replacement: Schritt 6, Bild 2 von 2
    • Unwrap the cable lining surrounding the throttle cable.
    • Track the throttle cable to the control box.
    • Disconnect the JST-SM connector from the main controller.
    • Take caution while handling these wires. They can be easily damaged.
  7. New Speed 26-inch Electric Bike Throttle Replacement: Schritt 7, Bild 1 von 2 New Speed 26-inch Electric Bike Throttle Replacement: Schritt 7, Bild 2 von 2
    • Cut the zip ties found along the frame of the bike.
    • Remove the throttle and its wires from the frame of the bike.
    • Be careful not to cut too close to the wires, as you could risk damaging them or hurting yourself.
Abschluss
To reassemble your device, follow the steps in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Arnold
176 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 34
Insgesamt: 837
