Einleitung
The throttle on an electric bike is important for proper function. When the throttle mode is engaged, the motor provides power, propelling the bike forward, similarly to a motorcycle or electric scooter. Without a working throttle, an electric bike loses important functionality, becoming little more than a regular, pedal-operated bike.
This guide will walk you through the steps to replace the throttle on a 26-inch New Speed electric bike. Make sure that your bike is off and not receiving power before starting.
Was du brauchst
Remove the 3/32" Allen screw from the top of the throttle.
Remove the two 2mm Phillips screws from the back of the control box.
Repeat this process for the other side of the control box. 4 screws will be removed in total.
Unwrap the cable lining surrounding the throttle cable.
Track the throttle cable to the control box.
Disconnect the JST-SM connector from the main controller.
Cut the zip ties found along the frame of the bike.
Remove the throttle and its wires from the frame of the bike.
To reassemble your device, follow the steps in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
