Einleitung
This is a guide on how to replace the motherboard from inside the NexiGo NS32. There are 13 specific steps in this guide that describe how to take the motherboard out of the controller. Be careful not to damage any of the internal components.
Was du brauchst
Grip the white battery connector and pull it directly out of its motherboard socket.
Remove the three 9 mm Phillips screws that secure the joystick PCB.
Flip up the black ZIF connector locking flap on the left side of the joystick PCB.
Pull the ribbon cable directly out of its socket.
Flip up the black ZIF locking flap that secures the trigger assembly ribbon cable.
Disconnect the ribbon cable.
Remove the two 9 mm Phillips screws that secure the motherboard to the front case.
