Was du brauchst
Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
Slide the tool along the edge to work the back cover off.
Remove the tape covering the motherboard.
Remove the silver tape holding the white ribbon cables to the battery.
Use a spudger to carefully disconnect the battery connector from the motherboard.
Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
Use a spudger to disconnect the two camera lenses from the device.
Carefully lift the black connector to release the cameras.
