Einleitung
Did the glass on your Nextbook 8 screen break? Use this guide to replace the glass on the front screen.
Was du brauchst
Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
Slide the tool along the edge to work the back cover off.
Remove the tape covering the motherboard.
Remove the silver tape holding the white ribbon cables to the battery.
Use a spudger to carefully disconnect the battery connector from the motherboard.
Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
Remove the 5 black screws on the motherboard.
Carefully lift the motherboard off of the device and remove.
Remove the two screws that hold the brackets in place.
Remove the two silver brackets that hold the screen in place.
Remove the one silver screw on the small green circuit board at the bottom of the device.
Set aside the small circuit board for now.
With the device face down, use a spudger to lift the screen off of the glass from the right side.
12 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
Thank you for this!
Ok thanks for the guide very helpful. Where can I pick a glass up at? And what's the going price?
My repair kit has specifically the touch glass meaning i need to separate the glass form the frame, how do you do this?
I just found the frame can be separated from the glass with a spudger-type thing, I used a fine blade like a craft knife (be careful!!). started at the bottom inside end and worked my way around, trying not to damage the frame in the process. Just to clarify this is for the NX785QC8G.
The glass is attached to the frame with adhesive, so the new glass will need to be stuck back on in a similar way. It’s strange that this part wasn’t mentioned in the instructions, as it was supposed to be for replacing the actual glass digitiser screen, but didn’t quite get there… hope this is of some help.. although it’s 2021 now and you’ve probably gone and bought a new one lol ;) I love my tablet (well, my 4yr-old does) but I stood on it and I happened to have a digitiser on hand.
I need a screen replacement guid like this one but for the Nextbook Ares 8 not 8a
