Einleitung
You need a thin tool to get the back cover off. If a plastic opening tool is not available, a guitar pick works just fine. Use caution when removing the back cover and inside parts.
Ersatzteile
Kein Ersatzteil erforderlich.
Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
Slide the tool along the edge to work the back cover off.
Remove the tape covering the motherboard.
Remove the silver tape holding the white ribbon cables to the battery.
Use a spudger to carefully disconnect the battery connector from the motherboard.
Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
Pull the ribbon cables out of the connectors with tweezers or two fingers.
Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
Use a spudger to lift up the black tabs on the three ZIF connectors.
Use ESD safe tweezers to pull the ribbon cables out of the three connectors.
Remove the 5 black screws on the motherboard.
Carefully lift the motherboard off of the device and remove.
Remove the two screws that hold the brackets in place.
Remove the two silver brackets that hold the screen in place.
Remove the one silver screw on the small green circuit board at the bottom of the device.
Set aside the small circuit board for now.
With the device face down, use a spudger to lift the screen off of the glass from the right side.
21 weitere Nutzer haben diese Anleitung absolviert.
