Zum Hauptinhalt wechseln
Nextbook Flexx 10 Camera Replacement
Was du brauchst
  1. Nextbook Flexx 10  Camera Replacement, Front and Rear Camera: Schritt 1, Bild 1 von 3 Nextbook Flexx 10  Camera Replacement, Front and Rear Camera: Schritt 1, Bild 2 von 3 Nextbook Flexx 10  Camera Replacement, Front and Rear Camera: Schritt 1, Bild 3 von 3
    • Remove the top section by pushing the middle button in the center of the base and lift on the screen.
  2. Nextbook Flexx 10  Camera Replacement: Schritt 2, Bild 1 von 3 Nextbook Flexx 10  Camera Replacement: Schritt 2, Bild 2 von 3 Nextbook Flexx 10  Camera Replacement: Schritt 2, Bild 3 von 3
    • Remove the black back panel of the screen.
  3. Nextbook Flexx 10  Camera Replacement: Schritt 3, Bild 1 von 2 Nextbook Flexx 10  Camera Replacement: Schritt 3, Bild 2 von 2
    • Place the panel screen down.
    • Identify the cameras at the top center.
  4. Nextbook Flexx 10  Camera Replacement: Schritt 4, Bild 1 von 3 Nextbook Flexx 10  Camera Replacement: Schritt 4, Bild 2 von 3 Nextbook Flexx 10  Camera Replacement: Schritt 4, Bild 3 von 3
    • Find the front camera.
    • Follow the gold strip to where it connects to the device.
    • There is a black piece that is holding the gold strip. Flip this up to release the camera.
    • Follow bullets above for the rear facing camera.
  5. Nextbook Flexx 10  Camera Replacement: Schritt 5, Bild 1 von 2 Nextbook Flexx 10  Camera Replacement: Schritt 5, Bild 2 von 2
    • Insert new camera into each slot, make connections, and close the black flap.
    • Snap back panel back onto the back of the screen.
    • Put screen and the keyboard back together.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 316
