Einleitung
The button sheet on the Nextplay NP109CR is sometimes placed incorrectly on the device. This prevents the buttons from working correctly. This guide will fix and place the buttons correctly on to the sheet. Use this guide to disassemble the device to reach the buttons. Follow the step by step instructions to re-position the buttons.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Unscrew the two screws with a Phillips #0 screwdriver on the top side of the device right in front of the eight buttons.
    • Unscrew the two screws with a Phillips #0 screwdriver on the top side of the device right in front of the eight buttons.
  2. Remove the lid from the device.
    • Remove the lid from the device.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Unscrew the four screws with a Phillips #0 Screwdriver from the pink button sheet.
    • Unscrew the four screws with a Phillips #0 Screwdriver from the pink button sheet.
  5. Remove the pink button sheet from the device by pulling out each button. Remove the pink button sheet from the device by pulling out each button.
    • Remove the pink button sheet from the device by pulling out each button.
Abschluss
Reverse these steps to reassemble the device.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Chotipong Chamchalaem
77 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-50, Forte Fall 2012 Mitglied von Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Mitglieder
8 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 230
