Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the device over so it is upside-down.
    • Turn the device over so it is upside-down.
  2. Unscrew the 4 screws closest to the screen.
    • Unscrew the 4 screws closest to the screen.
  3. Flip over the device so it is right side up.
    • Flip over the device so it is right side up.
  4. Unscrew the 2 screws on the top of the device, next to the docking plug.
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Take off top piece by using slight force and pulling off.
    • Take off top piece by using slight force and pulling off.
  6. Unscrew the button board with smaller screwdriver.
    • Unscrew the button board with smaller screwdriver.
  7. Lift off the button board.
    • Lift off the button board.
  8. Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Lift the screen vertically straight up.
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Flip the screen and the logic board over to the right side.
    • Flip the screen and the logic board over to the right side.
  11. Pull out the white plug that goes from the speakers to the logic board.
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
Abschluss
Michelle Read
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-50, Forte Fall 2012 Mitglied von Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 306
