Zum Hauptinhalt wechseln
Nexus 10 Front Facing Camera Replacement
Was du brauchst
    1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: Schritt 1, Bild 1 von 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: Schritt 1, Bild 2 von 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: Schritt 1, Bild 3 von 3
      • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
      Frag FixBot
      Kommentar hinzufügen
    2. Nexus 10 Front Facing Camera Replacement: Schritt 2, Bild 1 von 3 Nexus 10 Front Facing Camera Replacement: Schritt 2, Bild 2 von 3 Nexus 10 Front Facing Camera Replacement: Schritt 2, Bild 3 von 3
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
      Frag FixBot
    3. Nexus 10 Front Facing Camera Replacement: Schritt 3, Bild 1 von 3 Nexus 10 Front Facing Camera Replacement: Schritt 3, Bild 2 von 3 Nexus 10 Front Facing Camera Replacement: Schritt 3, Bild 3 von 3
      • Lift latch on front-facing camera connector.
      • Pull the connector toward the top of the device and remove the front-facing camera.
      Frag FixBot
Abschluss
Cal Poly, Team 34-18, Maness Spring 2016 Mitglied von Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 35
Insgesamt: 933
