Zum Hauptinhalt wechseln
Einleitung
It is happy to see the charging port is attached on daughterboard, it is convenient for us to replace the usb part. Now follow us to replace it by yourself.
Einführungsvideo
  1. Remove SIM card tray. Remove SIM card tray.
    • Remove SIM card tray.
  2. Heat up back glass panel. Use hobby knife to open a gap and cut the fierce sticker underneath rear glass panel. The back glass panel is easily shattered and the adhesive underneath is fierce. So be careful to pry this part.
    • Heat up back glass panel.
    • Use hobby knife to open a gap and cut the fierce sticker underneath rear glass panel.
    • The back glass panel is easily shattered and the adhesive underneath is fierce. So be careful to pry this part.
  3. Heat up bottom plastic panel. Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath. Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath.
    • Heat up bottom plastic panel.
    • Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath.
  4. Twist off 6 Phillips screws together. Insert guitar picks and plastic opening tool to separate front assembly from back cover. Attention: These two parts fit tightly.It is the toughest part to separate. You can also try using heavy-duty suction cup to disassemble them.
    • Twist off 6 Phillips screws together.
    • Insert guitar picks and plastic opening tool to separate front assembly from back cover.
    • Attention: These two parts fit tightly.It is the toughest part to separate. You can also try using heavy-duty suction cup to disassemble them.
  5. Unscrew one Phillips screw. Remove metal bracket securing flex contactors. Release 3 flex contactors and remove it .
    • Unscrew one Phillips screw.
    • Remove metal bracket securing flex contactors.
    • Release 3 flex contactors and remove it .
    • This flex is used to connect motherboard and daughterboard.
  6. Disconnect signal cable contactor and twist off one Phillips screw. Remove daughterboard. Remove daughterboard.
    • Disconnect signal cable contactor and twist off one Phillips screw.
    • Remove daughterboard.
  7. Here is the daughterboard. The charging port is attached here.
    • Here is the daughterboard. The charging port is attached here.
Abschluss
23 weitere Nutzer haben diese Anleitung absolviert.
Witrigs
66.246 Reputation
380 Anleitungen geschrieben
Do you know the part number of the daughterboard, or where I can buy a replacement?
Ezequiel Arneodo - Antwort
Global Direct Parts seems to have OEM parts. Don't go with eBay and stuff. The ones I saw are cheap knockoffs that don't work right (even when they say OEM).
Sunny Wu -
Do we need more adhesive or everything will stick back with heat?
Will Taylor - Antwort
I have replaced my battery. You most likely will need more adhesive. I just plan on using some double sided tape as the original glue was too tough in case I have to open it again. You can just buy a case for it after. It will keep everything nice and tight on there.
Sunny Wu -
To replace the daugherboard, step #5 can largely be skipped - just remove the cable from the daugherboard and move on to step #6. This phone is a true PITA to take apart.
ashlux - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 12
Insgesamt: 17,621
