Einleitung
Use this guide to replace the loudspeaker in your Nexus 6P smartphone. When reassembling your phone apply new adhesive where it is necessary.
Was du brauchst
Use a SIM card eject tool, to pop out and remove the SIM card tray.
Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
Slide the opening pick underneath the plastic cover to cut the adhesive.
Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
Pry off the glass cover.
Remove the six Phillips #00 screws.
Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
Insert a second opening pick and slide it to the top left corner.
Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
Remove the rear cover.
Remove the Philipps #000 screw.
Use tweezers to remove the metal plate.
Use the flat end of a spudger, to disconnect the battery flex cable.
Disconnect the main flex cable with a spudger.
Use tweezers to unplug the antenna cable.
Remove the Phillips #000 screw.
Unscrew the Philipps #000 screw.
Use the flat end of a spudger to pry off the loudspeaker.
Use tweezers to grab the loudspeaker and remove it.
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it's necessary.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
