Zum Hauptinhalt wechseln
Nexus 9 Vibrator Replacement
Was du brauchst
  1. Nexus 9 Vibrator Replacement, Rear Case: Schritt 1, Bild 1 von 3 Nexus 9 Vibrator Replacement, Rear Case: Schritt 1, Bild 2 von 3 Nexus 9 Vibrator Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Vibrator Replacement, Vibrator Daughterboard: Schritt 2, Bild 1 von 1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 Vibrator Replacement: Schritt 3, Bild 1 von 2 Nexus 9 Vibrator Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 Vibrator Replacement: Schritt 4, Bild 1 von 3 Nexus 9 Vibrator Replacement: Schritt 4, Bild 2 von 3 Nexus 9 Vibrator Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 Vibrator Replacement: Schritt 5, Bild 1 von 1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  6. Nexus 9 Vibrator Replacement, Vibrator: Schritt 6, Bild 1 von 2 Nexus 9 Vibrator Replacement, Vibrator: Schritt 6, Bild 2 von 2
    • Use a pair of tweezers to remove the vibrator from the device.
Abschluss
Geoff Wacker
89.889 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 308
