Einleitung
installing the battery housing
Was du brauchst
Using the plastic opening tools, pry the left bottom corner of the battery up.
Remove the two Torx T5 screws.
Remove the one Philips #00 screw.
Using the plastic opening tool, pry up the battery housing upwards.
Push pry tool down, undoing the plastic tab.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
