Zum Hauptinhalt wechseln
Nexus One Camera Replacement
Was du brauchst
  1. Nexus One Camera Replacement, Rear Cover: Schritt 1, Bild 1 von 2 Nexus One Camera Replacement, Rear Cover: Schritt 1, Bild 2 von 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Camera Replacement: Schritt 2, Bild 1 von 1
    • The rear cover slides up and off.
  3. Nexus One Camera Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Camera Replacement: Schritt 4, Bild 1 von 1
    • Pull the battery up and out.
  5. Nexus One Camera Replacement, Battery Housing: Schritt 5, Bild 1 von 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Camera Replacement: Schritt 6, Bild 1 von 2 Nexus One Camera Replacement: Schritt 6, Bild 2 von 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Camera Replacement: Schritt 7, Bild 1 von 2 Nexus One Camera Replacement: Schritt 7, Bild 2 von 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Camera Replacement: Schritt 8, Bild 1 von 2 Nexus One Camera Replacement: Schritt 8, Bild 2 von 2
    • Pry the top tab of the battery housing.
  9. Nexus One Camera Replacement: Schritt 9, Bild 1 von 2 Nexus One Camera Replacement: Schritt 9, Bild 2 von 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Camera Replacement: Schritt 10, Bild 1 von 2 Nexus One Camera Replacement: Schritt 10, Bild 2 von 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Camera Replacement, Camera: Schritt 11, Bild 1 von 3 Nexus One Camera Replacement, Camera: Schritt 11, Bild 2 von 3 Nexus One Camera Replacement, Camera: Schritt 11, Bild 3 von 3
    • Place the spudger under the metal cover and pry upwards. (shoot bottom side first with tabbed clip)
    • Swap the spudger to the other side of the cover base. Pry upwards. (fix?)
    • Grasp the camera module and pull up.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Niklas Johnson
1.207 Reputation
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 3,498
