Einleitung
installing the flash
Was du brauchst
Using the plastic opening tools, pry the left bottom corner of the battery up.
Remove the two Torx T5 screws.
Remove the one Philips #00 screw.
Using the plastic opening tool, pry up the battery housing upwards.
Push pry tool down, undoing the plastic tab.
Insert the spudger under the bottom of the flash board
Twist the spudger to lift and release the flash board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
