Zum Hauptinhalt wechseln
Nexus One Motherboards Replacement
Was du brauchst
  1. Nexus One Motherboards Replacement, Rear Cover: Schritt 1, Bild 1 von 2 Nexus One Motherboards Replacement, Rear Cover: Schritt 1, Bild 2 von 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Motherboards Replacement: Schritt 2, Bild 1 von 1
    • The rear cover slides up and off.
  3. Nexus One Motherboards Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Motherboards Replacement: Schritt 4, Bild 1 von 1
    • Pull the battery up and out.
  5. Nexus One Motherboards Replacement, Battery Housing: Schritt 5, Bild 1 von 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Motherboards Replacement: Schritt 6, Bild 1 von 2 Nexus One Motherboards Replacement: Schritt 6, Bild 2 von 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Motherboards Replacement: Schritt 7, Bild 1 von 2 Nexus One Motherboards Replacement: Schritt 7, Bild 2 von 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Motherboards Replacement: Schritt 8, Bild 1 von 2 Nexus One Motherboards Replacement: Schritt 8, Bild 2 von 2
    • Pry the top tab of the battery housing.
  9. Nexus One Motherboards Replacement: Schritt 9, Bild 1 von 2 Nexus One Motherboards Replacement: Schritt 9, Bild 2 von 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Motherboards Replacement: Schritt 10, Bild 1 von 2 Nexus One Motherboards Replacement: Schritt 10, Bild 2 von 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Motherboards Replacement, Lower Cover: Schritt 11, Bild 1 von 2 Nexus One Motherboards Replacement, Lower Cover: Schritt 11, Bild 2 von 2
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  12. Nexus One Motherboards Replacement, Antenna Housing: Schritt 12, Bild 1 von 1
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
  13. Nexus One Motherboards Replacement, Secondary Microphone: Schritt 13, Bild 1 von 2 Nexus One Motherboards Replacement, Secondary Microphone: Schritt 13, Bild 2 von 2
    • Using the spudger, pry upwards on the second microphone connector.
  14. Nexus One Motherboards Replacement: Schritt 14, Bild 1 von 1
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
  15. Nexus One Motherboards Replacement, Motherboards: Schritt 15, Bild 1 von 2 Nexus One Motherboards Replacement, Motherboards: Schritt 15, Bild 2 von 2
    • Insert the spudger under the connector.
    • Push the spudger up and twist to release the connector.
    • Repeat for the next connector.
  16. Nexus One Motherboards Replacement: Schritt 16, Bild 1 von 3 Nexus One Motherboards Replacement: Schritt 16, Bild 2 von 3 Nexus One Motherboards Replacement: Schritt 16, Bild 3 von 3
    • Push on the USB port to expose the black connector.
    • Use the spudger to pry the connector upwards.
  17. Nexus One Motherboards Replacement: Schritt 17, Bild 1 von 2 Nexus One Motherboards Replacement: Schritt 17, Bild 2 von 2
    • Place the spugder under the antenna connector.
    • Pry connector up vertically.
  18. Nexus One Motherboards Replacement: Schritt 18, Bild 1 von 3 Nexus One Motherboards Replacement: Schritt 18, Bild 2 von 3 Nexus One Motherboards Replacement: Schritt 18, Bild 3 von 3
    • Insert the spudger into tab above the camera.
    • Slide upwards until the board detaches from the case.
  19. Nexus One Motherboards Replacement: Schritt 19, Bild 1 von 1
    • Press the pointed tip of the spudger into the space below the button assembly.
    • Wiggle the spudger tip towards the outside of the button.
    • The button assembly is under some tension and may fly off.
  20. Nexus One Motherboards Replacement: Schritt 20, Bild 1 von 1
    • Push the pointed tip of the spudger into the base of the side button board.
    • Lift up, the board will disconnect from the case.
  21. Nexus One Motherboards Replacement: Schritt 21, Bild 1 von 3 Nexus One Motherboards Replacement: Schritt 21, Bild 2 von 3 Nexus One Motherboards Replacement: Schritt 21, Bild 3 von 3
    • Push on the lower motherboard until it slides under the case support.
    • The motherboard assembly comes out as a single piece.
    • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Niklas Johnson
1.207 Reputation
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 4,141
