Zum Hauptinhalt wechseln
Nexus One Secondary Microphone Replacement
Was du brauchst
  1. Nexus One Secondary Microphone Replacement, Rear Cover: Schritt 1, Bild 1 von 2 Nexus One Secondary Microphone Replacement, Rear Cover: Schritt 1, Bild 2 von 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Secondary Microphone Replacement: Schritt 2, Bild 1 von 1
    • The rear cover slides up and off.
  3. Nexus One Secondary Microphone Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Secondary Microphone Replacement: Schritt 4, Bild 1 von 1
    • Pull the battery up and out.
  5. Nexus One Secondary Microphone Replacement, Battery Housing: Schritt 5, Bild 1 von 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Secondary Microphone Replacement: Schritt 6, Bild 1 von 2 Nexus One Secondary Microphone Replacement: Schritt 6, Bild 2 von 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Secondary Microphone Replacement: Schritt 7, Bild 1 von 2 Nexus One Secondary Microphone Replacement: Schritt 7, Bild 2 von 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Secondary Microphone Replacement: Schritt 8, Bild 1 von 2 Nexus One Secondary Microphone Replacement: Schritt 8, Bild 2 von 2
    • Pry the top tab of the battery housing.
  9. Nexus One Secondary Microphone Replacement: Schritt 9, Bild 1 von 2 Nexus One Secondary Microphone Replacement: Schritt 9, Bild 2 von 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Secondary Microphone Replacement: Schritt 10, Bild 1 von 2 Nexus One Secondary Microphone Replacement: Schritt 10, Bild 2 von 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Secondary Microphone Replacement, Secondary Microphone: Schritt 11, Bild 1 von 2 Nexus One Secondary Microphone Replacement, Secondary Microphone: Schritt 11, Bild 2 von 2
    • Using the spudger, pry upwards on the second microphone connector.
  12. Nexus One Secondary Microphone Replacement: Schritt 12, Bild 1 von 1
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
Abschluss
Niklas Johnson
1.207 Reputation
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,256
