Einleitung
Replace your worn out inner dome daughterboard: which contains Atmel ATMEGA328P, NXP Semiconductors 44501 Near-Field Communications Controller, TXC 8.00 MHz Crystal Quartz Oscillator, YF04E, and the status LED.
Ersatzteile
Kein Ersatzteil erforderlich.
Squeeze and pull to pop the cap off of the Nexus Q.
Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
Once the antenna is disconnected, simply pull it off the outside of the inner dome.
Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
