Zum Hauptinhalt wechseln
Nexus Q LED Board Replacement
Was du brauchst
  1. Nexus Q LED Board Replacement, Ball Bearing Ring: Schritt 1, Bild 1 von 1
    • Squeeze and pull the cap to remove it from the Nexus Q.
  2. Nexus Q LED Board Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
  3. Nexus Q LED Board Replacement: Schritt 3, Bild 1 von 1
    • Undo the ZIF connector by prying it with a spudger.
  4. Nexus Q LED Board Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
    • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
  5. Nexus Q LED Board Replacement: Schritt 5, Bild 1 von 1
    • View the bottom half of the Nexus Q.
    • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
  6. Nexus Q LED Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the ball bearing ring.
    • When placing a new ring in its place, make sure to orient it right or the top will not close.
  7. Nexus Q LED Board Replacement, LED Board: Schritt 7, Bild 1 von 2 Nexus Q LED Board Replacement, LED Board: Schritt 7, Bild 2 von 2
    • Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
    • Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
  8. Nexus Q LED Board Replacement: Schritt 8, Bild 1 von 2 Nexus Q LED Board Replacement: Schritt 8, Bild 2 von 2
    • With the diffuser out, we are exposed to the LED Board.
    • Use a spudger to lightly lift the LED board out.
Abschluss
Taewan Kim
22 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-10, Maness Winter 2013 Mitglied von Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 513
