Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Internal prereq..
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the six Phillips screws securing the rear inner frame to the inner case.
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  2. Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  3. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Insert the plastic opening tool to the right of the power button. Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  5. In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S. In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  6. Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  7. Lift and remove the rear inner frame from the Nexus S.
    • Lift and remove the rear inner frame from the Nexus S.
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 287
