Einleitung
This repair might be needed if your NikePlus Sportband screen has been damaged due to being drop or stepping on the device.
Was du brauchst
To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
Use the metal tweezers to pry the screen casing from the body of the device.
The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
Flip the body of the device over so that the screen is now on the bottom.
The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
Flip the body of the device back over so that the screen is facing up.
Using the tweezers, gently lift the screen from body of the device.
