Zum Hauptinhalt wechseln
Nike SportWatch GPS Back Panel Replacement
Was du brauchst
  1. Nike SportWatch GPS Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six #000 size 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Back Panel Replacement: Schritt 3, Bild 1 von 1
    • Pry the black plastic piece above the battery out using a nylon or metal spudger.
    • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
  4. Nike SportWatch GPS Back Panel Replacement: Schritt 4, Bild 1 von 1
    • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
  5. Nike SportWatch GPS Back Panel Replacement: Schritt 5, Bild 1 von 1
    • After taking the battery out, you will be left with just the band and the backpanel part of the watch.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ian Eichorn
678 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Mitglieder
5 Anleitungen geschrieben
3 Kommentare
Where can I find a new watch band?
rhalljr68 - Antwort
You can´t. Nike left us alone
Leonardo Cartier - Antwort
So, no way to repair the band then if there's no replacement parts? :(
roycy Tan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 2,545
