Einleitung
In this guide you will replace the front panel of the watch. It will involve taking it apart the watch to its entirety and using a heating device to easily remove the screen.
Was du brauchst
Face the watch upside down so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
Two size #000 2.5 mm long screws will appear at the top of the main board. Unscrew them using a size 000 Phillips head screwdriver.
Carefully use the blue plastic opening tool to pry the main board out of the front panel.
Use an iOpener that has been heated in the microwave for about a minute, or until warm. Place it on the front screen of the watch. Let it rest there for a minute.
