Einleitung
These step by step instructions will allow you to easily remove the LCD screen on the watch and replace it with a new one.
Was du brauchst
First, place the watch upside down so the back of the watch is exposed. Unscrew the six size #000 5 mm long screws located on the back panel using a size 000 Phillips head screwdriver.
Then, unscrew the two main board size #000 2.5 mm long screws using a size 000 Phillips head screwdriver.
Carefully use the blue plastic opening tool to pry the main board out of the front panel.
Pull the plastic piece that is highlighted in the picture out from the back of the screen.
For reassembly, make sure the highlighted area in the picture, goes over the black plastic piece that was removed in the previous step.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Hello, I found your article very interesting, I was just wondering do you know where I can buy a replacement screen?
Thank you
I googled the part number on the screen
