Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
In the event that the GPS unit stops picking up a signal, it may require a replacement. This guide involves opening the watch and removing the main board on the watch. A wire connects the GPS to the main board, so after the replacement is finished, soldering the wire back to the main board may be necessary.
  1. First, unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
    • First, unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Then, gently pull the watch band and front screen apart.
    • Then, gently pull the watch band and front screen apart.
  3. Two size #000 2.5 mm screws on the main board will appear. Unscrew them using a size 000 Phillips head screwdriver.
    • Two size #000 2.5 mm screws on the main board will appear. Unscrew them using a size 000 Phillips head screwdriver.
  4. Carefully use the blue plastic removal tool to pry the main board out of the front panel.
    • Carefully use the blue plastic removal tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
  5. Using a nylon or metal spudger, cut the orange tape that covers the wire for the GPS.
    • Using a nylon or metal spudger, cut the orange tape that covers the wire for the GPS.
  6. Break the metal part of the wire that connects the GPS to the main board using the metal tool.
    • Break the metal part of the wire that connects the GPS to the main board using the metal tool.
    • When you are re-assembling the watch, you will have to solder the wire back together.
  7. Use the plastic opening tool to pry out the GPS unit.
    • Use the plastic opening tool to pry out the GPS unit.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Ian Eichorn
672 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Mitglieder
5 Anleitungen geschrieben
which GPS unit is it?
charles - Antwort
what gps unit is it?
charles - Antwort
I would also like to know what GPS unit that is and if it is possible to find a replacement or a compatible unit?
avs4820 - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 9
Insgesamt: 1,676
