Einleitung
Here we are going to show you how to replace the O-Ring on the Nikon 1 AW 1 Camera.
Was du brauchst
Press and hold the lens release button, twist the lens in a clockwise motion, then pull it off of the camera.
Squeeze the O-ring under the lens support to push out the O-ring. Use a plastic opening tool to get under the O-ring, and slowly work around the metal lens support to pull the O-ring completely out.
Ein Kommentar
Hello, it appears that Nikon has discontinued the Nikon 1 AW1 WP-O2000 O-ring. Can anyone suggest a non-OEM alternatives?
