Zum Hauptinhalt wechseln
Nikon COOLPIX P2 LCD Screen Replacement
Was du brauchst
  1. Nikon COOLPIX P2 LCD Screen Replacement, Case: Schritt 1, Bild 1 von 1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 LCD Screen Replacement: Schritt 5, Bild 1 von 3 Nikon COOLPIX P2 LCD Screen Replacement: Schritt 5, Bild 2 von 3 Nikon COOLPIX P2 LCD Screen Replacement: Schritt 5, Bild 3 von 3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 LCD Screen Replacement: Schritt 8, Bild 1 von 2 Nikon COOLPIX P2 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 LCD Screen Replacement, LCD Screen: Schritt 9, Bild 1 von 2 Nikon COOLPIX P2 LCD Screen Replacement, LCD Screen: Schritt 9, Bild 2 von 2
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 LCD Screen Replacement: Schritt 10, Bild 1 von 2 Nikon COOLPIX P2 LCD Screen Replacement: Schritt 10, Bild 2 von 2
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 LCD Screen Replacement: Schritt 11, Bild 1 von 1
Abschluss
Joshua Avery
31 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-28, Amido Winter 2012 Mitglied von Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,135
