Zum Hauptinhalt wechseln
Nikon COOLPIX P600 Battery Replacement
  1. Nikon COOLPIX P600 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the camera upside down so that the lens is facing away from you.
  2. Nikon COOLPIX P600 Battery Replacement: Schritt 2, Bild 1 von 2 Nikon COOLPIX P600 Battery Replacement: Schritt 2, Bild 2 von 2
    • Slide the switch on the battery cover towards the center of the camera.
  3. Nikon COOLPIX P600 Battery Replacement: Schritt 3, Bild 1 von 2 Nikon COOLPIX P600 Battery Replacement: Schritt 3, Bild 2 von 2
    • Once the battery cover is open, push the solid yellow tab in the direction of the arrow. This will then eject the battery out of the camera.
Abschluss
To reassemble your device, follow these instructions in reverse order. Make sure the battery is pushed back into the battery compartment enough to have the yellow latch seen in step three click back over the top of the battery before attempting to close the battery cover.
Angehängte Dokumente
CSU Fullerton, Team 1-5, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 1-5, Bruce Fall 2015
CSUF-BRUCE-F15S1G5
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 31
Insgesamt: 2,175
