Zum Hauptinhalt wechseln
Nikon COOLPIX P7700 Focusing Screen Replacement
Was du brauchst
  1. Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: Schritt 1, Bild 1 von 2 Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: Schritt 1, Bild 2 von 2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
    Frag FixBot
    Kommentar hinzufügen
  2. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 2, Bild 1 von 1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
    Frag FixBot
  3. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
    Frag FixBot
  4. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
    Frag FixBot
  5. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
    Frag FixBot
  6. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 6, Bild 1 von 2 Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 6, Bild 2 von 2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
    Frag FixBot
  7. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the back casing.
    Frag FixBot
  8. Nikon COOLPIX P7700 Focusing Screen Replacement, Focusing Screen: Schritt 8, Bild 1 von 1
    • Once the back casing is off, locate the 4.3 mm silver screw near the top of the camera and remove it using the Phillips #00 screwdriver.
    Frag FixBot
  9. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the metal sheet from the camera.
    • It is okay to remove the orange ribbon from the camera.
    Frag FixBot
  10. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 10, Bild 1 von 3 Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 10, Bild 2 von 3 Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 10, Bild 3 von 3
    • Remove the four 4.3 mm silver screws located on the ends of the chip using the Phillips #00 screwdriver.
    Frag FixBot
  11. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 11, Bild 1 von 2 Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 11, Bild 2 von 2
    • Remove the two 4.3 mm silver screws on the far right side of the camera using the Phillips #00 screwdriver.
    Frag FixBot
  12. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 12, Bild 1 von 2 Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 12, Bild 2 von 2
    • Lift and detach connector from board as shown.
    Frag FixBot
  13. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 13, Bild 1 von 1
    • Remove the board from the camera to locate lens opening
    Frag FixBot
  14. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 14, Bild 1 von 1
    • Remove the 4.3 mm screws from the metal sheet using the Phillips #00 screwdriver.
    Frag FixBot
  15. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 15, Bild 1 von 1
    • Lift the metal sheet up and out of the camera.
    Frag FixBot
  16. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 16, Bild 1 von 1
    • Locate the reflective lens.
    Frag FixBot
  17. Nikon COOLPIX P7700 Focusing Screen Replacement: Schritt 17, Bild 1 von 1
    • Remove the lens from the camera.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Colorado Springs, Team 2-7, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-7, Panko Spring 2015
UCCS-PANKO-S15S2G7
3 Mitglieder
10 Anleitungen geschrieben
2 Kommentare zur Anleitung
Hey I have a P7700 that shows a lens error and focusing doesn't work.
I took it apart and removed the focus motor and it seems that the focus lens moves as it should but when turning it on the picture will be blurry for a second until the lens error comes up.
What issue is fixed by replacing this focus lens?
Dominik Bessler - Antwort Teilen
Hello.
Do you have a service procedure to fix the exposure dial in this camera?
Hugo - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 49
Insgesamt: 2,688
