Zum Hauptinhalt wechseln
Nikon COOLPIX S3600 Battery Cover Replacement
Was du brauchst
  1. Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: Schritt 1, Bild 1 von 2 Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: Schritt 1, Bild 2 von 2
    • Locate the battery cover on the right side of the bottom of the camera.
    • To open the cover, gently slide it in the direction indicated by the arrow.
    Frag FixBot
    Kommentar hinzufügen
  2. Nikon COOLPIX S3600 Battery Cover Replacement: Schritt 2, Bild 1 von 3 Nikon COOLPIX S3600 Battery Cover Replacement: Schritt 2, Bild 2 von 3 Nikon COOLPIX S3600 Battery Cover Replacement: Schritt 2, Bild 3 von 3
    • Once the battery cover door is open, insert the pointed end of a spudger underneath the metal door hinge.
    • Gently twist the spudger; the battery door cover should pop off.
    • Completely remove the cover from the hinge.
    Frag FixBot
Abschluss
To reattach the battery cover door, align the metal hinge with the plastic cover and press the plastic cover downward until it snaps into place.
Colorado Springs, Team 1-3, May Spring 2015 Mitglied von Colorado Springs, Team 1-3, May Spring 2015
UCCS-MAY-S15S1G3
6 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 30
Insgesamt: 764
