Einleitung
If your camera is not saving pictures, you may need to remove or replace the memory card. Follow this replacement guide for help!
Push latch downwards to open the battery hatch located on the bottom right.
Memory card is located above the battery compartment.
Push in the memory card until you can't push it in any more and release.
Memory card should be slightly popped up.
Now you can carefully remove the memory card.
Eine weitere Person hat diese Anleitung absolviert.
