Einleitung
If your front casing has come loose or needs to be replaced, follow this guid to remove your current front casing from the camera.
Was du brauchst
Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
Remove the 4x3mm on the opposite side near the selector wheel.
Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
Pry the back panel away from the body of the camera, using the space you just opened up.
A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
Remove the three 3x3mm screws that attach the front casing to the bottom.
Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
