Einleitung
If your screen has stopped working or needs to be replaced for some other reason, follow this guide to remove your current screen.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
Remove the 5x3mm screw holding down the panel on the side closest to the lens.
Remove the 4x3mm on the opposite side near the selector wheel.
Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
Pry the back panel away from the body of the camera, using the space you just opened up.
A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
