Einleitung
If the lens is not working properly or giving a lens error, you need to take it out to inspect or replace it.
Was du brauchst
Remove the three 4 mm screws from the bottom of the camera using a #00 Phillips screwdriver.
Remove the single 3.5 mm screw from the bottom of the camera using a #00 Phillips screwdriver.
With the bottom of the camera facing you, slide the latch on the compartment to the left.
Swing the battery compartment door open.
Remove the 3.5 mm screw from the inside with a #00 Phillips screwdriver.
With the screen facing you, locate the two 3.5 mm screws on the left face of the camera. Remove them using a #00 Phillips screwdriver.
With the screen facing you, locate the three 3.5 mm screws on the right face of the camera. Remove them with a #00 Phillips screwdriver.
Locate the crease where the case comes together.
Using a plastic prying tool, pry at the line to remove the camera case.
Slide the yellow navigation panel to the right so that it can be lifted up.
Locate the magnet and copper tape on the left side of the camera.
Gently pull the copper tape off of the metal plate.
Lift the screen up and swing it to the right, exposing the circuit board underneath.
Detach the ribbon cable that is connecting the LCD screen and the circuit board.
Disconnect the ribbon cable from the left side of the camera.
You can do this by lifting the small black strip with your nail and rotating it 60 degrees on top of the connector. These connectors are fragile so don't use to much force. Now you can easily take the flat cable out (same for the other connectors).
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, remove the lens cover from the lens.
Remove the 3.5 mm screw holding down the Wi-Fi card.
Move the Wi-Fi card away from the device.
Using your fingers, push the lens from the front of the camera to loosen it.
Lift the lens unit from the other side so it is free from the case.
15 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
So, does this mean that one the camera is put back together the lens open automatically again?
Ja, das ist so.
Hallo,
bereits das dritte mal habe ich ein Objektiv bei der S9500 ausgebaut und ein Ersatz eingebaut, jedesmal geht die Kamera nicht mehr an.
Was kann das nur sein? Einen Akku Türschalter hat diese Kamera ja nicht.
Habe schon hunderte Nikons zerlegt, passiert mir nur bei dieser Type, da muss doch was verstecktes eingebaut sein?
