Zum Hauptinhalt wechseln
Nikon CoolPix S5 Battery Replacement
Was du brauchst
  1. Nikon CoolPix S5 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • This will cause the SD/Battery cover to pop open.
  2. Nikon CoolPix S5 Battery Replacement: Schritt 2, Bild 1 von 1
    • Press orange clip to eject battery (battery not shown).
  3. Nikon CoolPix S5 Battery Replacement: Schritt 3, Bild 1 von 1
    • While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • This will cause the battery to fall into the hand (battery not shown).
  4. Nikon CoolPix S5 Battery Replacement: Schritt 4, Bild 1 von 1
    • Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
  5. Nikon CoolPix S5 Battery Replacement: Schritt 5, Bild 1 von 1
    • Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Clemson, Team 12-5, Benson Spring 2013 Mitglied von Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 724
