Einleitung
This guide is to be used to install the battery in the case that the battery dies or no longer functions properly. A Phillips screwdriver will be needed to complete this installation.
Was du brauchst
Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
This will cause the SD/Battery cover to pop open.
While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
This will cause the battery to fall into the hand (battery not shown).
Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
