Einleitung
Your Nikon Coolpix S5 has buttons on the back that control the operation of the camera. These buttons can become damaged or loose, which makes it hard to use the camera. This guide explains how to open the back of the camera and install replacement buttons.
Disconnect the camera from its charger before beginning this repair.
Was du brauchst
Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
Repeat the removal of the two screws on the other side of the camera.
The plate holding the buttons is on the right side of the camera. Use your fingers to open it to the right, away from the LCD screen. Do not twist or force the panel open. It should lift easily.
3 weitere Personen haben diese Anleitung absolviert.
