Einleitung
This guide is to be used to install the plastic LCD screen cover in the case that it becomes damaged or no longer functions properly due to overuse. A Phillips screwdriver will be needed to complete this installation.
Was du brauchst
Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
Repeat the removal of the two screws on the other side of the camera.
Press lightly on the outer surface of the plastic LCD screen cover in each corner.
The plastic LCD screen cover should pop out of the back plate.
2 weitere Personen haben diese Anleitung absolviert.
