Zum Hauptinhalt wechseln
Nikon Coolpix 4600 Lens and Flash Assembly Replacement
Was du brauchst
  1. Nikon Coolpix 4600 Lens and Flash Assembly Replacement, Front and Rear Case: Schritt 1, Bild 1 von 2 Nikon Coolpix 4600 Lens and Flash Assembly Replacement, Front and Rear Case: Schritt 1, Bild 2 von 2
    • Locate the six screws on the exterior of the camera. There will be two 3.3 mm screws on the bottom and two 5.25 mm screws either side.
    • Using a Phillips 00 screwdriver, remove all of the six screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 2, Bild 2 von 2
    • Gently separate the front and back casing by prying the two sides open with your hands. DO NOT separate them fully, as it could damage internal components.
    • The front case is attached to internal components and cannot be removed independently
    Frag FixBot
  3. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 3, Bild 1 von 1
    • Examine the connection between the ribbon cable and the motherboard closely. Identify the two grey tabs on each side of the connecting bracket.
    • Slide the grey tabs toward the bottom of the camera to release the ribbon cable. Gently disconnect the ribbon cable from the motherboard.
    • Once the ribbon cable is disconnected, you can now carefully separate the back case from the front case.
    Frag FixBot
  4. Nikon Coolpix 4600 Lens and Flash Assembly Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Locate and remove the four 4.25 mm screws on the motherboard using a Phillips 00 screw driver.
    Frag FixBot
  5. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 5, Bild 1 von 1
    • Remove the ribbon cable on the top right of the motherboard. To remove the cable, slide the two grey tabs, located on both sides, towards the top of the camera and gently pull the cable out.
    Frag FixBot
  6. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 6, Bild 1 von 1
    • Turning the camera to the left and tilting it up, look at the left end of the motherboard to locate the grey bracket.
    • Twist the grey bracket counter clockwise to remove it from the silver LCD bracket.
    Frag FixBot
  7. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 7, Bild 1 von 2 Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 7, Bild 2 von 2
    • Using a Phillips 00 screwdriver, remove the 4.25 mm screw on bottom left edge of the LCD bracket.
    • Lift off the LCD bracket and slip the grey bracket through the LCD bracket. The LCD bracket should now be completely removed.
    Frag FixBot
  8. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 8, Bild 1 von 2 Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 8, Bild 2 von 2
    • Desolder the wire (both black and red) from the motherboard.
    • Remove the orange ribbon cable. This is done by sliding each side of the lock bar toward the center of the camera. Gently pull on the ribbon cable to remove.
    Frag FixBot
  9. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 9, Bild 1 von 2 Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 9, Bild 2 von 2
    • Gently peel back the black tape on the bottom, middle of the motherboard. Underneath you will find a screw.
    • Remove the 4.25 mm screw with a Phillips 00 screwdriver.
    Frag FixBot
  10. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 10, Bild 1 von 1
    • Gently pull the motherboard away from the lens.
    • Flip the camera over.
    • Connecting the motherboard to the front case are seven wires.
    • Desolder the seven wires.
    • If you are only removing the motherboard as an intermediate step to get to other components, do not desolder yet, as not all wires need to be removed.
    • Be careful when desoldering the wires. If you do not know how to properly desolder a wire, seek help to prevent damage to the motherboard. Also, make sure the soldering crunches don't fall into the lens case.
    Frag FixBot
  11. Nikon Coolpix 4600 Lens and Flash Assembly Replacement, Lens and Flash Assembly: Schritt 11, Bild 1 von 2 Nikon Coolpix 4600 Lens and Flash Assembly Replacement, Lens and Flash Assembly: Schritt 11, Bild 2 von 2
    • The flash and lens assembly should now be separate from the motherboard.
    • Locate the capacitor. It is the component that looks similar in size and shape to a AAA battery.
    • With the lens upright and facing you, gently lift the capacitor up and to the left to remove main flash assembly.
    Frag FixBot
  12. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 12, Bild 1 von 1
    • Locate the 4.8 mm screw above the middle of lens on the front side and remove it.
    • The flash bulb can now be lifted off the lens assembly.
    Frag FixBot
  13. Nikon Coolpix 4600 Lens and Flash Assembly Replacement: Schritt 13, Bild 1 von 1
    • The lens assembly is now separated from all other components.
    • Follow the steps in reverse order to re-install new lens.
    Frag FixBot
Abschluss
Cal Poly, Team 9-43, Regan Spring 2012 Mitglied von Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 51
Insgesamt: 2,239
