Einleitung
This guide will walk you through how to remove the back case of the Nikon Coolpix 5400. The processes only requires a handful of screws to be removed and a few connecting wires. When removing the wire connectors, be careful not to break the plastic fittings.
Was du brauchst
Use a plastic opening tool to gently remove the back case from the rest of the camera.
Remove the two 4.0mm Phillips #0 screws holding the circuit board to the back case.
Pull the LCD screen cables in the direction that the wires are exiting the circuit board.
Pull the toggle wheel wire connector up and away from the top of the camera.
Pull the button control panel wire connector up and away from the top of the camera.
Remove the six 3.0mm Phillips #0 screws holding the button control panel.
Remove the back cover from the camera body.
