Zum Hauptinhalt wechseln
Nikon Coolpix 5400 Battery Replacement
Was du brauchst
  1. Nikon Coolpix 5400 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the camera so that the base is oriented facing up and the front of the camera is facing towards you.
  2. Nikon Coolpix 5400 Battery Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix 5400 Battery Replacement: Schritt 2, Bild 2 von 2
    • Push the battery compartment door latch, located on the right-hand side of the camera, away from you to release the catch.
    • Release the latch and pull your hand away. The spring inside the compartment will push both the battery up and the door open.
    • Push the battery door the rest of the way open to fully expose the battery.
  3. Nikon Coolpix 5400 Battery Replacement: Schritt 3, Bild 1 von 1
    • Grasp the battery with your thumb and forefinger and pull up and out of the camera housing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 394
