Einleitung
Use this guide to replace the front cover.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
Carefully open the back cover. Take care as there are connectors still attached.
Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
Remove the two 2.5mm screws on the bottom of the left side, after having removed the back cover.
