Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace the front cover.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the four 3.0mm screws on the bottom of the camera.
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. Remove the two 3.0mm screws on the right side of the camera.
    • Remove the two 3.0mm screws on the right side of the camera.
  4. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Carefully open the back cover. Take care as there are connectors still attached.
    • Carefully open the back cover. Take care as there are connectors still attached.
  6. Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  7. Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
  8. Be careful of metallic parts which are loose and will fall out.
    • Be careful of metallic parts which are loose and will fall out.
    • Remove the two 2.5mm screws on the bottom of the left side, after having removed the back cover.
  9. Remove the two 3.0mm screws on the right side of the camera.
  10. Remove front cover.
    • Remove front cover.
Abschluss
Kaky Payne
79 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 12-38, Regan Spring 2012 Mitglied von Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 14
Insgesamt: 1,208
