Einleitung
This guide is for the user of the Nikon Coolpix A900 camera. As the Nikon Coolpix A900 camera is used, the battery will need to be taken out for either charging or replacement. This can be noted by the user if the camera will not turn on, or if the camera displays a message stating that the battery needs to be charged.
When this time comes, this guide can be used to locate the battery and to help with the removal process. Removing the battery allows it to be recharged and replaced so the camera can be used again.
Orient the camera so that it is upside down, with the lens facing towards you.
Slide the battery door lock left to unlock it.
The battery door will automatically open.
