Zum Hauptinhalt wechseln
Nikon Coolpix A900 Monitor Replacement
Was du brauchst
  1. Nikon Coolpix A900 Monitor Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. Nikon Coolpix A900 Monitor Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix A900 Monitor Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
  3. Nikon Coolpix A900 Monitor Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix A900 Monitor Replacement: Schritt 3, Bild 2 von 2
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. Nikon Coolpix A900 Monitor Replacement, Rear Case: Schritt 4, Bild 1 von 3 Nikon Coolpix A900 Monitor Replacement, Rear Case: Schritt 4, Bild 2 von 3 Nikon Coolpix A900 Monitor Replacement, Rear Case: Schritt 4, Bild 3 von 3
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. Nikon Coolpix A900 Monitor Replacement: Schritt 5, Bild 1 von 3 Nikon Coolpix A900 Monitor Replacement: Schritt 5, Bild 2 von 3 Nikon Coolpix A900 Monitor Replacement: Schritt 5, Bild 3 von 3
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. Nikon Coolpix A900 Monitor Replacement: Schritt 6, Bild 1 von 3 Nikon Coolpix A900 Monitor Replacement: Schritt 6, Bild 2 von 3 Nikon Coolpix A900 Monitor Replacement: Schritt 6, Bild 3 von 3
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
  7. Nikon Coolpix A900 Monitor Replacement: Schritt 7, Bild 1 von 2 Nikon Coolpix A900 Monitor Replacement: Schritt 7, Bild 2 von 2
    • Remove the two black 2.5 mm screws from the monitor bracket.
  8. Nikon Coolpix A900 Monitor Replacement: Schritt 8, Bild 1 von 2 Nikon Coolpix A900 Monitor Replacement: Schritt 8, Bild 2 von 2
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. Nikon Coolpix A900 Monitor Replacement: Schritt 9, Bild 1 von 3 Nikon Coolpix A900 Monitor Replacement: Schritt 9, Bild 2 von 3 Nikon Coolpix A900 Monitor Replacement: Schritt 9, Bild 3 von 3
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
  10. Nikon Coolpix A900 Monitor Replacement, Monitor: Schritt 10, Bild 1 von 3 Nikon Coolpix A900 Monitor Replacement, Monitor: Schritt 10, Bild 2 von 3 Nikon Coolpix A900 Monitor Replacement, Monitor: Schritt 10, Bild 3 von 3
    • Set the rear case screen down.
    • Remove the two 2.5 mm black Phillips #00 screws.
  11. Nikon Coolpix A900 Monitor Replacement: Schritt 11, Bild 1 von 2 Nikon Coolpix A900 Monitor Replacement: Schritt 11, Bild 2 von 2
    • Separate the rear case from the monitor assembly.
    • Make sure that the ribbon cable does not snag on the rear case when removing it.
Abschluss
4 Kommentare
Where did you get a new monitor for your camera?
photower - Antwort
Bonjour superbe étape par étape ou puis je trouver l’écran LCD du NIKON A900 je ne le trouve pas ! merci de votre retour !
et un grand merci à des personnes comme vous qui nous aide nous pauvre novice !!!
Laurent Farrugia - Antwort
This is excellent but where would you get a new 3” monitor?
Panders McMulluon - Antwort
Have you tried AliExpress or Ebay?
photower -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 39
Insgesamt: 1,057
