Einleitung
This guide will show you how to remove and replace the rear case of the Nikon Coolpix A900.
You may want to replace the rear case of the camera if it gets dropped, or develops a crack.
In most cases, you will need to remove the rear case to access other components that need to be replaced.
Before you get started, make sure that you have several containers for small parts so you can stay organized.
Was du brauchst
Orient the camera so that it is upside down, with the lens facing towards you.
Slide the battery door lock left to unlock it.
The battery door will automatically open.
Orient the camera upside down, with the lens facing away from you.
Remove the two 3mm Phillips #00 screws from the right.
Remove the two 3.4mm Phillips #00 screws from the left.
Turn the camera on its side, with the lens facing away from you.
Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
Place the camera upright with the lens facing away from you.
Move the monitor down, and remove two 4.4 mm screws.
Place the camera lens down, while supporting the rear case.
Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
With the ribbons disconnected, you can now remove the rear case.
