Einleitung
This guide provides instruction for safely exposing the LCD screen and internal guts of the Nikon Coolpix AW130.
Was du brauchst
Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
After pressing the yellow tab, the battery should loosen.
Slowly pull the battery completely out.
Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
Remove the upper cover (connected by glue) and unscrew the single Philips screw.
Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Did this to inspect the inside of the zoom lever, which is broken and will (only with difficulty) zoom in, and won't (at all) zoom out.
Followed the instructions to the letter but, after all screws removed, was unable to get the back panel separated from the body of the camera. Either there is glue, or some sort of latching mechanism present - or something missing in the description. Didn't want to break anything completely, as camera is still just about usable - so I gave up. I don't think the camera will be water-proof any more after this.
